Guest Pegasus76 Posted May 5, 2002 Share Posted May 5, 2002 What other parts do you need for a 280ZXT swap into a 260Z besides needing the engine Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted May 5, 2002 Share Posted May 5, 2002 I'm gathering the parts now...but... Unless you're going with a standalone, you're going to need the ECU, harness, AFM. If you're dropping it into a 260Z, I believe you'll also need a fuel pump and possibly even fuel tank, but I've heard differing opinions on this... I can't believe this popular of a swap hasn't warranted a VFAQ. So, as soon as I get it done, I'm going to do one up. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 8, 2002 Share Posted May 8, 2002 You need the harness, AFM, ECU, Injectors. You also need the igniter and coil assembly. If you are not dropping in a turbo engine, you need the distribor and its driveshaft. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 8, 2002 Share Posted May 8, 2002 Oh, you need an efi fuel pump, and if you are not running to much extra boost, the stock Nissan EFI pump is ok, if you want to run more boost or a rising rate of gain FPR, you need a stouter pump. Cartech has a nice one that is really stout and wrapped in rubber called a peirburg. It flows 200 liters per hour, so it is a hoss. In a 240Z, I had to take the tank to a radiator shop to enlarge the pick=up tube. I went with a .5 inch, althouh I think I would get the sump from summit and go that route if I had to do it again. Run a fuel line to the engine to feed it, and use the old fuel line for the return line, and I am pretty sure I had to reroute the return line at the tank, so it might not be a bad idea to have that enlarged as well. The stock return line in a 240 would not flow enough fuel and it raised the fuel pressure above what it was supposed to be. Good luck. Rumor has it a stock 75 280z tank fits a 240, and it is already set up for FI. I could not verify that though, so check before you buy one if you go that route before you pay. Quote Link to comment Share on other sites More sharing options...
