Cam Timming affecting vacum
I never used a vaccum gauge to time an engine but I would say retarding the timing would lower the vaccum as would an improper underich or overrich fuel mixture. Your fuel mixture should be correct before attempting any timing changes by means of a vaccum gauge. I maybe wrong on this.. but not this: You should be any where between a "steady needle reading" of 15 and 18 inches of vaccum on a stock engine at idle.
Guest Tom Scala
I retarded my cam 4 crank degrees and saw little or no loss of manifold vacuum at idle. It's still around 19" at 1000rpm, but upper rpm (above 5500) power is up noticeably.
