How to connect Hazard Switch to painless Kit
It's been a long time since I've fiddled with OEM wiring; but the hazard switch circuitry is integral with the turn signal wiring....meaning if you change one, by definition you've changed the other.  You didn't specify if you've completely replaced original wiring with a Painless harness; or only partially replaced.  You also didn't specify which year and model car you've got; but IIRC these portions of the harnesses only changed wire color from year to year....the overall wiring concept did not.  The attached linked schematic should help you either way; and you'll have to adjust accordingly based on your current wiring configuration.
Hope this helps.  If not, reply with additional details, and maybe even some photos if they would help illustrate your issue.
