ZG Flares posting for the 300th time
clarkspeed
Just went through the process of installing some small carbon fiber ZG's on a 280Z.  Goal is squeezing some 18x8 wheels underneath.  Probably nothing to learn here, but this is how I do it.
First we sized everything up and looked at it.  Then looked some more.  Then swap them all around and looked more.  Then repeat 10 times.  Finally we drew a fat line with a Sharpie on tape where the cuts would go.
This is where it gets fun.  We cut the rear inner panel slightly longer than the outer panel.  This allows the inner fender to be bent and lightly hammered out to match up with the outside panel for welding.  Stripped back the paint just far enough were we were certain it would not show around the flare. Then weld um up.
For the front's we bent a length of 3/16 rod and tack welded it in place.  This stiffens the fender back to OEM or better.  I have seen a cut fender wrinkle before when doing hot laps on a track. Weld and grind smooth.
Edited by clarkspeed
  • Like 1
