Guest Anonymous Posted December 11, 2002 Share Posted December 11, 2002 out of what car could one source out the "perfect intercooler" to cool a 280zxt.??(on a budget) Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted December 11, 2002 Share Posted December 11, 2002 93.5 -98 twin turbo supra (not big but about five inches thick) "should" be good for about 350hp safe. npr (isuzu truck) there is two different ones i dont know whats the difference (use search to find more info on it) that one is long tall and two inches thick. that one "should" be good for about 400hp. those are in my opinion two best ones. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted December 11, 2002 Share Posted December 11, 2002 Actually, there are 3. The smallest one has smaller pipes pointing straight forward. Its OK for a mild upgrade. The medium-size is the most popular. It is physically bigger than the small one and has 2 7/8 pipes angling up and out slightly. The larger and most desirable has the same shape as the medium but is coated black, is taller and has less but much larger tubes. Here is a pic of the medium and large. Quote Link to comment Share on other sites More sharing options...
Guest shortyz Posted December 13, 2002 Share Posted December 13, 2002 looked at the skyline gtr intercooler? Quote Link to comment Share on other sites More sharing options...
slownrusty Posted December 13, 2002 Share Posted December 13, 2002 Scottie - Can you tell me what the dimensions of the core on the Medium Sized NPR IC is (left on your pic), if its not too much trouble. Thanks! - Yasin Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted December 13, 2002 Share Posted December 13, 2002 http://zdriver.com/members/scottiegnz/ic.html Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 14, 2002 Share Posted December 14, 2002 I used an intercooler from a Skyline GT-R. I had to modify the end tanks in order to get it to fit, but it sure does fill the front grill. The modifications required me to cut and cap off the outward facing 3" inlet/outlet pipes and put in forward facing 2.50" inlet/outlets. The core alone is 23" wide by 14" tall and 2" thick. That's without the end tanks. With the modicactions, the inlets and outlets exit on each side of the radiator. With everything installed I have both 2.5" inlet/outlet pipes and a 3" fresh air pipe coming out the front. The fresh air pipe connects to a K&N cone filter mounted just in front of the intercooler. It was a tight fit, but I was still able to retain the hood spring and run a stock 280ZXT auto oil cooler with lines. All this in a 72 240Z. Quote Link to comment Share on other sites More sharing options...
