weber throttle body?
Guest joeyhammer
Guest joeyhammer
anybody know what a used weber throttle bodies worth? my friends got one.. 60 mm.. also i have a mustang tb from a 90 gt.. thats supposed to work with some mods.. should i buy the weber? or mod the mustan tb? thanks guys
If the Weber TB is in great shape, I say between $80 to $100, as thats how much it will cost you to get a used 240SXKA24DE TB from a scrap yard and the 1" spacer made. If its your buddy, then he should cut you a sweet deal too ;)
I have not seen the Mustang TB mounted on a "L" engine, but would like to see how that hooks up. I have heard of people using it as well.
Hope that helps ya - Yasin
you dont have to run a spacer, i dont have one, but then you do have to do two things, first you you have to run a throttle cable or modify the heck out the ball rod linkage, and you have to take the cover off the tps, which is also iffy, you have to clean it way more often than usual.
thats what i did, and 60mm here we go.
