ATTN: Tony Fruzza
280z-racer
Hrmmm. How about finding a shop with a REALLY big Bridgeport that you can mount the car to.
I don't see how it's possible. I thought you had to remove everything from the block (pistons, etc.) and mount it to a fixture in order to ensure proper alignment and tolerances during the machining process.
Unless you're referring to some other process that is similar to decking. But even then, whatever fancy process it is (with a high dollar tool that you mount to the block??) will send material all over the place and into the bores and water and oil passages. Not good.
