Ivan280zt Posted February 4, 2003 Share Posted February 4, 2003 dang its been few long nights of me making out with my baby (z that is but i woudnt call it baby at this time ) finally got all wiring mess figured out (turbo swap in 77z) and also installed msd 6a box to go with ss blaster coil and difference in spark is just amaizing it must be at least two or three times stronger. make long story short. now i have spark (finally) and motor turns over just fine but it wont crank just keeps spinning over. it has spark and fuel (yeah i actually remembared to put gas in it afther i drained old one) so what else should i check out. tomorow is my day off so i have plenty of time to work on it i just need to know what all to look at and which way to test it (for example how to test injectors and fuel regulator....) any idea is more than welcome as usual so just throw them at me. Ivan (no its not running yet ) Quote Link to comment Share on other sites More sharing options...
speeder Posted February 5, 2003 Share Posted February 5, 2003 Couple obvious things- Make sure the fuel pump is running and pressurizing the fuel rail - I use a hardware store pressure guage and a tee fitting between the filter and fuel rail. Fuel pressure should be about 43psi with the car not running and starter engaged. There is a contact in the air flow meter that turns on the fuel pump relay, which turns on the pump. Check that stuff if your pump isn't turning on. If you have fuel pressure, make sure your injectors are firing. If they are working, you can hear them clicking when the car is turned over with the starter by putting the tip of a screwdriver on the body of an injector and the screwdriver handle to your ear. If you hear no clicking from the injectors, check connections to the injector resistor bank and ECU. Quote Link to comment Share on other sites More sharing options...
fl327 Posted February 5, 2003 Share Posted February 5, 2003 make sure the ignition transistor is grounded check ignition switch, pull the little eight pin connector and clean it, that is acc circuit and also power to the coil specifically, bottom two pins on that connector check for power with key on. Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted February 5, 2003 Author Share Posted February 5, 2003 thanks for replys guys i alredy have great news. z is finally runing. i had to hot wire fuel pump and redo ignition wires (they were way out of place) and she cranked right up. Ivan (ohhh yeah its running) Quote Link to comment Share on other sites More sharing options...
fl327 Posted February 6, 2003 Share Posted February 6, 2003 do a doughnut. Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted February 6, 2003 Author Share Posted February 6, 2003 Len as soon as i get insurance and tag i am sure that there is gonna be more than just one hehehehe Ivan Quote Link to comment Share on other sites More sharing options...
speeder Posted February 6, 2003 Share Posted February 6, 2003 Good news, Dood! Do some 's Quote Link to comment Share on other sites More sharing options...
fl327 Posted February 6, 2003 Share Posted February 6, 2003 good good, thats what i like to hear. Quote Link to comment Share on other sites More sharing options...
