A to Z Posted October 4 Share Posted October 4 A week or two ago, I began an engine and transmission project, thinking there may yet be another rip snorter in my future. Maybe a B210 or maybe a Roadster? I bought a ATLAS 5 cylinder engine, it's a 3.7, or 3700 cc inline 5. lengthwise about the same as a 2000 roadster engine, but yes it is taller. Like my 4200 it is all aluminum, 4 valves per cylinder, dohc, with VVTi on the exhaust cam. I additionally got a 4 speed automatic for it, a GM "4L60e", that is a lock up setup, where there isn't a lot of slush and stuff. I have already gotten some parts for the 3700, and I will post updates on here. Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 4 Author Share Posted October 4 I went ahead and worked on the 3700 today. I removed the balance shafts, and used the Badlands Industries delete kit. I then cleaned up and re-sealed the rear plate, installed the flex plate with a few bolts in case I want to do a compression test later, and then got it on the engine stand. Int he pics you will see the 4 speed automatic trans for it, a lockup unit GM "4L60e", that I will rebuild with all the tough parts and probably a 3000 RPM stall, unsure at this point. PICS: 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 4 Author Share Posted October 4 Some of the parts I have gotten for the 3700 engine project so far. Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 5 Author Share Posted October 5 10-04-2026. I took some time today, and went ahead and removed the wiring harness, the intake manifold and some other parts bolted to the block. The stuff still attached, all the bolts are now broken loose and will be easy to deal with as we go. The parts I removed either got tossed, or put into a pile.....I then cleaned them up and took a couple quick pics. Engine looks a lot smaller once you get all the "junk" off! PICS Quote Link to comment Share on other sites More sharing options...
A to Z Posted Thursday at 01:50 AM Author Share Posted Thursday at 01:50 AM 10-07-2026. I had a few moments today, So I took some measurements to get started on the DMZ intake DIY kit. Because of the intake, the original alternator location won't work, So I will make my own bracket and move it down to about the halfway mark. Plate steel or plate aluminum, M10X1.5 all thread screwed in to the threaded holes there, and start drilling holes and get it on there, and then slot holes as necessary to get belt alignment just right. PICS: 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted Friday at 01:53 AM Author Share Posted Friday at 01:53 AM 10-08-2026. I got the driver's side cleaned tonight. The oil pan and valve cover will be cleaned off the engine. One step closer to paint! Quote Link to comment Share on other sites More sharing options...
A to Z Posted Saturday at 11:14 PM Author Share Posted Saturday at 11:14 PM 10-10-2026. I finished cleaning the block and then painted it silver with engine enamel. Then I pulled the valvecover off, and did an initial cleaning on it. PICS: Quote Link to comment Share on other sites More sharing options...
