Guest timhypo Posted January 24, 2002 Share Posted January 24, 2002 Which crate motor and cam kit is that? I've been finding varying HP numbers on those GM crate motors. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 24, 2002 Share Posted January 24, 2002 I'm not certain I'd call the older small blocks down on power. It wasn't uncommon to see mid 300 hp out of them without even breathing hard. The LT1 is what 275hp or so stock? Torque difference is probably vastly different because the Tuned Port Injection was tuned for low to mid range torque. There is no doubt the LT1 is more efficient because of the fuel injection (and roller cam etc..). IMHO the major hassle in the DFI systems isn't usually the wiring, much of it is un-used, but your fuel system upgrade. The stock lines are a bit small, but that can be fixed with a low pressure pump from the main fuel tank to a small surge tank up front and the FI is feed from it. In the end its your choice, there isn't really a 'whats the best' because they all have they're compromises. (Early chevy good power, less fuel efficient, late model TPI requires mod's to breath well past 4800 RPM's). Either engine will make a good driver, the Fuel injection obviously will require less in the way of tune ups and be less persnickity in weather and altitude changes. Just an opinion of course. Good luck with your project. Regards, Lone Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 24, 2002 Share Posted January 24, 2002 An engine is what you make it.Change cam/intake/exhaust,ect.The horsepower possibilities are endless.Except for very high hp,the sbc foundation is basically the same it all depends on what you put in it.that`s my opinion anyway. Quote Link to comment Share on other sites More sharing options...
Guest kc6wfs Posted January 24, 2002 Share Posted January 24, 2002 Go here and do a search for "crate motors" http://www.sallee-chevrolet.com/Discus/board.html Also do a search for "hot cam" It's a great site and has a 800 number. Tom Sallee is a cool guy. Lots of answeres. Dave Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 25, 2002 Share Posted January 25, 2002 Just wanted to get some feedback on everyone's opinion's on the best choice for a hybrid. Looking for something that can be used as a daily driver. I really like the idea of an LT1 but the install looks much more difficult. wiring harness? smog equipment? etc, plus more upfront $$$? Older SBC are much cheaper (friend selling a decent running '71 350 + trans for ~$300) but down on power, less efficient, and (although we don't have smog nazis down here) I worry somewhat about inspections, an ~87 chasis with a pre '80 motor. Haven't really considered 5.0's much. So please, any opinions are welcomed. Quote Link to comment Share on other sites More sharing options...
Guest kc6wfs Posted January 25, 2002 Share Posted January 25, 2002 Hi Crash... boink.. hehe Buy a new GM Vortec crate motor and install GM's "hot cam kit" for the ZZ4's. Stock it will do ~350HP Will cost about 2K for the motor and cam set with springs, 1.6 rockers ect. Dave Yaaaa got a new one.. thanks!!!!! Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted January 25, 2002 Share Posted January 25, 2002 here are a few of the better deals in crate motors http://www.recycler.com/com/chevy_only/page2.htm#383 http://www.amerspeed.com/engine_prices.htm http://www.sdpc2000.com/cart.asp?action=catalog_start&catid=120 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 25, 2002 Share Posted January 25, 2002 You can run the early SBC to get your swap complete then add the Edelbrock or Holley fuel injection later. Summit sells the Edelbrock injection for about $1900. That gives you the injection, computer, harness, and fuel pump. Quote Link to comment Share on other sites More sharing options...
