Corzette Posted October 7, 2002 Share Posted October 7, 2002 Hey guys, I am considering going 1 3/4 S&S headers but won't I lose power vice using the 1 5/8s?. CorZette Quote Link to comment Share on other sites More sharing options...
Tim240z Posted October 7, 2002 Share Posted October 7, 2002 I don't think that any power gains/losses will be significant enough to effect your decision. The one issue with the S&S headers is ground clearance, esp. on the pass. side. I also found with mine that the collector placing made the use of these headers impossible (using T56). I ended up cutting them up and converting them to Tri Ys. Now I have much better ground clearance, and better flowing headers (I am assuming). See Here Tim Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted November 7, 2002 Share Posted November 7, 2002 Corzette: I'm no expert in this area. And if you've been following past posts in this area, you've notice quit a bit of confusion and angst over what is the best set up. I'm still trying to get good info as to the way to go when I upgrade my 383. I've been reading a bunch of material that I received from "Headers by Ed". It's quit interesting and disspells some old theories that bigger is better. Depending upon HP and application, 1 5/8" work quit well for engines cranking out well over 400 ponies in low to mid range(2000-6000 rpm). When one gets into race application, then bigger becomes better particularily over 6000 rpm. But please don't take my word for it!! Ed's website is www.headersbyed.com BTW, I'm almost convinced to stay with 1 5/8" headers-I just wish I could find a set in long tube form that would fit instead of block huggers which don't perform as well. Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted November 8, 2002 Share Posted November 8, 2002 Hey Guy's super Chevy did a 383 build a while back and the best power and performance results were from a long tube 1 5/8" header hands down. Mike Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted November 8, 2002 Share Posted November 8, 2002 Hey Mike! Got any more info??? Website? Do you know if they might fit in a ZV8? Rick Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted November 8, 2002 Share Posted November 8, 2002 Hey Rick, My wife has the van and my magazines are in there. I will try to give you more info tonight. Mike Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted November 9, 2002 Share Posted November 9, 2002 Rick, Found the article on the 383 449 hp build up. It is called the twister and has at least 3 articles on the build spread over three months starting in june 2002 issue of Chevy High Performance. If you do not have access to them I will send them to you as I am through with them. The Aug. 2002 issue talks specifically about the build dynoing and best results were with the Headman 1 5/8" long tube headers. Let me know if you want them. Mike Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted November 9, 2002 Share Posted November 9, 2002 I stand corrected there are 4 articles on the build. Mike Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted November 12, 2002 Share Posted November 12, 2002 Yo Mike: Yes, please send them to me! I'll pay for any cost incurred. Contact me @ my email address zhaba@daeo.net and I'll give you my mailing address. Thanx, Rick Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted November 16, 2002 Share Posted November 16, 2002 Rick, did you ever get my email? I never heard back from you. Mike Quote Link to comment Share on other sites More sharing options...
