ratedZ Posted November 19, 2001 Share Posted November 19, 2001 Just wondering what you guys with the 280zxt's are using in terms of bigger injectors. I'm planning on upgrading mine real soon but don't know where to start. Give me any info I need to start my re-search and maybe even installation tips etc. Thanks. Quote Link to comment Share on other sites More sharing options...
Sean 83ZXT Posted November 19, 2001 Share Posted November 19, 2001 look at Arif's post or do a search for Benz injectors Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted November 19, 2001 Share Posted November 19, 2001 benz injectors were from 74 to 76 450 v8.they have a hose on top like stock nissan injectors.you will need a programmable efi to run these-the on time pulse width with oem efi will be too long.the nissan injectors are about 25 lb/hr.mercs are 48-so at idle the on time will have to be much less.i replaced a set of these on a 450 slc in late 80's-i shouldnt have thrown them away.could have sent them to rc engineering for cleaning and flow test. Quote Link to comment Share on other sites More sharing options...
Arif Posted November 21, 2001 Share Posted November 21, 2001 Another option if you don't have a programable computer is to possibly go with the SVO/Merkur injectors. They are rated at 370cc so if you do use them you will more than likely have to address the AFM or the engine will run rich if at all. Also there are modifications that need to be done to the injectors. Scottie used to have the "how to" on his old website. I upgraded from those and went with the 75 Mercedes 450 sel injectors. But like someone said before they do require an aftermarket fuel system to run them. Quote Link to comment Share on other sites More sharing options...
