Cruez Posted December 6, 2001 Share Posted December 6, 2001 Hey guys....new to the board... I've been messing with Z's since I turned 16...And have always had at least one... Anyway, I have installed a Haltech in my '78 after doing mods to the engine that the stock FI couldn't keep up with. I am at my last stage but I cannot get the magnetic pickup to work correctly, I put a MSD 8509 signal converter but it doesnt create enough signal at startup. I took out the distributor and if I turn it fairly fast, the signal is fine.... What other alternative can I do that it fairly cheap?...I am on a tight budget... Quote Link to comment Share on other sites More sharing options...
TimZ Posted December 6, 2001 Share Posted December 6, 2001 That is a characteristic of variable reluctance mag pickups - the slower the rpm, the weaker the signal gets. What is your gap currently? It would probably help to get the gap as small as possible. Quote Link to comment Share on other sites More sharing options...
Cruez Posted December 6, 2001 Author Share Posted December 6, 2001 Not sure but close to .030 What about alternatives? Quote Link to comment Share on other sites More sharing options...
Drax240z Posted December 14, 2001 Share Posted December 14, 2001 I had a similar problem with my half-assed together electronic ignition. (the GM HEI module one, with mods) Anyway, once I lowered the gap things worked much better. To hell with factory specs, just move it a bit closer and see if it cures it. (not close enough to rub mind you) Quote Link to comment Share on other sites More sharing options...
Cruez Posted December 14, 2001 Author Share Posted December 14, 2001 Anyone???.. How about if I just got another distributor with an optical pickup??... Which car can I pull the distributor off of ?? Quote Link to comment Share on other sites More sharing options...
GrayZee Posted December 14, 2001 Share Posted December 14, 2001 Some L28 turbo engines have a light emitting diode type pickup, 1983 and maybe 82? Quote Link to comment Share on other sites More sharing options...
Guest Tom Scala Posted December 17, 2001 Share Posted December 17, 2001 .030" gap is WAY too big. Factory calls for .008"-.016". I agree,just tighten it up as much as you can before it touches. Quote Link to comment Share on other sites More sharing options...
