Guest bloodyknucklz Posted February 25, 2002 Share Posted February 25, 2002 Hello, Doing the fuel supply installation for my 240 turbo project and would like to know where to mount the new fuel pump. I have kept the 240 tank and have a Summit fuel sump welded to it. The supply is 3/8 and return is 5/16. Any ideas much appreciated. Thanks, Andrew Quote Link to comment Share on other sites More sharing options...
RB30-ZED Posted February 25, 2002 Share Posted February 25, 2002 The roller cell fuel pumps, like the Bosch unit most peaple use will push fuel all day, but they dont like to suck fuel, so if you arn't using a pre pump in the tank you must keep the main pump low and close to the tank. Most factory set ups that didnt use a prepump used a half inch hose to cut restriction Quote Link to comment Share on other sites More sharing options...
Mike C Posted February 27, 2002 Share Posted February 27, 2002 I bolted my Carter carb pump to the passenger side upright that supports the control arm. This works better with an R180 than the 200 however, but I did get it done. Quote Link to comment Share on other sites More sharing options...
