scarp Posted May 31, 2000 Share Posted May 31, 2000 [This message has been edited by scarp (edited November 13, 2000).] Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted May 31, 2000 Share Posted May 31, 2000 According to my calculations you now have $22,000!The sky is the limit, go build an awsome Z! Why did you sell it, after you finally got it running right? Quote Link to comment Share on other sites More sharing options...
MYRON Posted May 31, 2000 Share Posted May 31, 2000 STAN THE CARPENTER MAN! I will sell you my 280Z chassis or complete.... look at the pictures in members rides.. i have about 12k in it but will take a loss..... Quote Link to comment Share on other sites More sharing options...
scarp Posted June 5, 2000 Author Share Posted June 5, 2000 . [This message has been edited by scarp (edited November 13, 2000).] Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted June 5, 2000 Share Posted June 5, 2000 Stan,please keep us updated on your old car.I am very interested on how fast that z-car goes with that combo.Did he buy there SUPER CHIEF 565 crate motor?If so they claim it makes 1000hp and 785ft-lbs.WOW! [This message has been edited by RON JONES (edited June 05, 2000).] Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted June 5, 2000 Share Posted June 5, 2000 Stan,check this out. http://www.dragstore.com/cgi-bin/dcforum/dcboard.cgi put in your racing weight,in type of car, put door car,and your E.T. and it gives you your calculated HP. [This message has been edited by RON JONES (edited June 05, 2000).] [This message has been edited by RON JONES (edited June 05, 2000).] [This message has been edited by RON JONES (edited June 05, 2000).] [This message has been edited by RON JONES (edited June 05, 2000).] Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted June 6, 2000 Share Posted June 6, 2000 Ron, I checked out that site with the HP calculator and IMO, any formula that calculates HP and does not factor trapspeed is not going to be very accurate. MPH is the true indicator of HP and I think the following is a much more accurate formula and the HP result is at the wheels: (MPH squared / ET) * (weight with driver / 1000) / 9.1 yesterday I ran 12.41 @ 114.7 and my car weighs 2750 and the HP result is 320 at the wheels. I know I lost .5 on the ET because of the launch and if I changed the ET to 11.91, the HP would jump 13. However, if I increased the MPH by 5, the HP would jump 29. Perfect example of why this is more accurate is that you can reduce your ET dramatically by installing a very low diff ratio and not a single increase in HP. However, the only thing that will increase MPH is HP. Scottie Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted June 6, 2000 Share Posted June 6, 2000 Guess what the SUPPER CHEIF 565 goes for.$20,350. Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted June 6, 2000 Share Posted June 6, 2000 I,m sure your right scottie,but its fun anyway.On the other hand I use to have a 80 malibu w/468 and I use to change gears all the time,4.56,4.30,4.11,and the car use to run with in .05 and the same mph(up or down a couple mph) with all those gears.The only thing that would change is the rpm going trough the traps.The link that I posted tells me I have 853.96hp at the wheels.John Scott used my mph to calculate my HP and came up with 858(I think),I,m not sure if thats power at the wheels.Whats funny is it tells me I,m making 1110.14hp at the crank.Boy that dyno I go to must be way off,seeing as it only made 800hp even at the crank,he he he. [This message has been edited by RON JONES (edited June 05, 2000).] Quote Link to comment Share on other sites More sharing options...
scarp Posted June 6, 2000 Author Share Posted June 6, 2000 Ron i have what is called race 4.05 plus which is a pretty good sim program.... for all that want it I will email it to ya'll just tell me your Email address's Stan Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted June 6, 2000 Share Posted June 6, 2000 Ron, I dont know what your car weighs, but I guessed at 2600lbs with you in it and came up with 854hp at the wheels. If you apply the 80% rule that's 1068hp at the flywheel. BTW, I saw a Z-car at Lakeland Dragstrip (FL) Saturday night. I was in line and he was at the lights. It was purple and sounded like a big block. Did not hear his time or see the car for the rest of the night. Do you know of this car? Scottie Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted June 6, 2000 Share Posted June 6, 2000 Since we have traded emails you know that I think you should take that '72 Z and do a 1962 Ferrari 250 GTO from Thunder Ranch http://www.thunderranch.com/gto1.htm but then I am very biased! If you decide to do it please let me know if I can help. BTW I have a couple of new shots in my album if you are interested http://www.zing.com/album/?id=4294856715 Good luck. Quote Link to comment Share on other sites More sharing options...
scarp Posted June 6, 2000 Author Share Posted June 6, 2000 . [This message has been edited by scarp (edited November 13, 2000).] Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted June 6, 2000 Share Posted June 6, 2000 Scottie,The car w/me in it is 2710.No,I don,t know of the purple Z,next time your at the track check it out.Run the numbers again and see if they come close to that dragstore calculator. Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted June 6, 2000 Share Posted June 6, 2000 Stan,I can,t wait to here how that thing runs with that motor.I run a 8" 5700 stall converter and you would be very surprised how streetable it is,the problem I have is tire rub going over bumps and keeping it from geting to hot.Tell your brother wheelie bars are a must. [This message has been edited by RON JONES (edited June 05, 2000).] Quote Link to comment Share on other sites More sharing options...
scarp Posted June 6, 2000 Author Share Posted June 6, 2000 Ron Wheelie bars were part of the 9" setup so they are allready there... Stan Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted June 6, 2000 Share Posted June 6, 2000 Ron, with 2710lbs, the numbers are 890hp at the wheels and 1113hp at the flywheel using the 80% rule. In either case, those numbers broke my calculator, hehe. Scottie Quote Link to comment Share on other sites More sharing options...
