1FASTKINGCAB Posted September 1, 2002 Share Posted September 1, 2002 Is there a way to wire up two nissan mass air flow sensors? I would think that two could folw twice as much as one right? I have seen on a few turbo cars (SR22DET Silva) that the use a 3" "Y" pipe on the turbo inlet and two stock MAF's and two cone filters. just wondering if it coud work with a lightly moded ECM Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted September 6, 2002 Share Posted September 6, 2002 What you saw is likely some variant of the twin pop charger set-up JWT puts on the 300ZXTT's. You could check with them and see. In reality it should not be that hard to do. You wire up one, and you have to reset the fuel map to give out half the fuel it normally would since you have added another. Simple in theory, and pain in the ass in reality. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted September 7, 2002 Share Posted September 7, 2002 Check Supraforums.com for this. A bunch of Supra guys have done this several ways. They've used aftermarket boxes, they've done something to the voltage of the MAF, and who knows what else. It's not a Nissan specific deal but it should at least give you some ideas - it's not proven terribly easy or super effective I think but worth a shot. Quote Link to comment Share on other sites More sharing options...
Tony240ZT Posted September 7, 2002 Share Posted September 7, 2002 I would almost think that splitting the voltage output into 2 on both of them would work well. You do this by using two resistors of equal amount one connected to the output of the AFM/MAF the other is connected to ground, connect the two together and then hook your computer sensor wire up there in the middle of the two resistors. Do this for both the main output and temp. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted September 8, 2002 Share Posted September 8, 2002 I'm pretty sure the Supra guys found that trying to do the resistor thing didn't work well for them. I think they ended up using an Apexi piece or possibly a custom box.... Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted September 9, 2002 Share Posted September 9, 2002 I'm curiuos as to why you would need to do this? Are you making that much power? If so you should really look into a more realistic aproach to air managment such as JWT or an aftermarket computer. Quote Link to comment Share on other sites More sharing options...
