ecu pin # for the water temp sensor
bumble zee
There should be two sensors/senders in the thermostat housing. These sensors go to the Water Temp gauge in the dash and the second sensor is for the thermotime switch which runs the fuel injector cooling fan. The gauge sender wire is yellow and the thermotime sender is white. Neither of these wires run to the ECU rather they go to the vehicle main harness. On the turbo EFI the ECU receives the engine temperature signal from the CHTS.
Josh
