Olds 455
Guest Locutus
Guest Locutus
This doesn't relate to a Z car, but it is GM related so I thought I would ask you guys for advice. The sitiuation is I have a 455 in a olds delta 88, it has 48 orginal miles on it and it has been babied all its life so its a good engine. The question is, I also have a 1981 full size K-5 Blazer. My friend ran it dry on oil and it stopped running, after it kewled down it started but it uses alot of oil and she basically screwed the engine. I was thinking of putting the 455 into the Blazer, since all I really want is a good vehicle for towing a trailer and hauling stuff around. Nothing hi po, just a strong work horse. So I guess I need to know, is the bolt pattern the same for the tranny, motor mounts etc on a big block specifcally one in an olds? The main concern is the tranny, since it is 4X4 it would be a bitch to get a tranny to fit if its a different type and still keep the 4 wheel drive
Mike
Guest RON JONES
bellhousing is a different bolt pattern,I think JEGS sell an adapter plate to mount the chevy trans to the olds,buick,pont.bolt pattern.I think the motor mounts won,t be a problem.
Mike, I've got one of those adapters! (I'm an old Olds hotrodder) I can't remember, but I think you also have to space the converter to flexplate with appropriate washers. The olds 455 is a torque monster! Mondello makes lots of cool hipo parts. He probably put a couple of kids through college on my old(s) addiction! If you want to pay for shipping, about 10-12 lb, it, it yours. Let me know!
JS
Guest Locutus
sure send it on, it would be a good step in the right direction. email me and I will give you my address and phone number
Mike
Hey
I had a 455 olds , with a th350 and the rear end out of a 69' 98 olds. I put it in a 1964 ford shortbed pickup, tranny rearend and all. bone stock, that son of a gun would break yer neck and pop yer head off the back winder if ya wasnt carfull. Ran great on top end too!
74 260, sbc 350, 700r4, and a few little HP Mods.just gettin started good. speedtechcoatings.com
Guest needwaymorespeed
I have a 75 smogger olds 455- quote the worst ont they made- in a 65 olds jetstar 88 convert-5000 plus pound car and itll pull 15.90 all day long in saltlakecity UT-THATS AT 4500 elevation and serious traction problems-one tire fire with bias ply-
OLDSMOBILES ROCK!!!!!
they stuck the oldsmobile diesel-small block into 78-79-chevy trucks-if you get those motor mounts and the frame mounts and
use a trans adapter itll bolt in
good luck
I needwaymorespeed
I just got a deal on a an olds 455.
the casting #s prove it to be the
380hp model w/10.5 compression.
It is torn down and needs to be bored
and the crank needs to be turned but
i got it cheap with the th400 tranny and a
th375 tranny with electric kickdown.
Locotus plese respond to my email
Myron
Mike, adapter plate should be coming any day now. No charge. You can by me a beer someday!
Seen plenty of 10 and 11 second Olds in full bodied Cutlass/F85s/442s...at 6000ft. The best "stock" engine I ever had was the 425 ci out of a 67(?) Toronado. BIG lifters bores allowed killer camshafts. My main gripe was they were expensive to build and hated high RPMs. Funky trunion rockers with adjustable pushrods! Remember the 70 W30s? Knew a guy who put a stock 455 in a camaro and ran low 12s @ 6000ft.
JS
[This message has been edited by John Scott (edited June 01, 2000).]
John, the numbers that i gould find through
the grease were "GB1 9T" "048" "912 73"
"B12 73" some of these may be innacurate
because a "B" looks like an "8" and with my hand wrighting that "GB1 9T" might be
"GM 9T" the heads had huge intake valves
and factory guide plates and large almost
square ports with the corners kinda rounded out the ports look just like the # "0"
the intake is 4 barrell 3 "GMT 333841"
the block has "O or Q then E459752" on the front of the block. the back of the block has 3999289 and the words "high-perf pass 7"
under the cam gear
I honestly can't remember which heads were the most desirable, but I thought A/Bs. in a LARGE letter cast into the head. Joe Mondello, now probably run by his son, Bernard(I think) would know. There phone #s are still listed in perf. magazines. In any event, there cool engines that make lots of power at relatively low RPMs. Never seen guide plates on an Olds. Just the wierd trunion rocker mounts.
JS
JS
There should be a large letter on the front of the cylinder by the #1 spark plug
youll find a large A thru J letter
F being the most desirable-w30 0lds 442 19 70
C the second most 67-69 cars-these came with the small and large valves
B the thid on 66 cars
A the fourth found on 65 cars
it sounds like myron has a 68-9 olds toronado 455 block
oldsmobile rock-would love to stick one in a z-but too hravy and afraid the excess torque would twist car
needwaymorespeed
N.W.M.S...... redface.gif your olds info is commendable...(John remember F is for fast, later letter, better head,..got it) and I used to play with these. Too many years ago!
Did you or do you run the beasts? I remember how my cheapie engine stand would bend under the massive weight. My fist engine rebuild, back in '76, a guy named "Shorty" a dark man with a little beret, about 5' by 5', lifted my block (a 400) out of my mom's T-bird trunk!
JS
[This message has been edited by John Scott (edited June 03, 2000).]
Im planning a buildup of 1 455 for my 65 convertible-FULL SIZE BIG WHALE OF A CAR-
currently have all of the pieces just need to do the machine work and put it all together. Z car is first then 68 firebird then a new engine for the convertible-she runs well right now turns 15.9 pretty fast for a big boat-have beaten many 5.0s in salt lake with her-LOVE TO SEE THERE FACES!!!
NEEDWAYMORESPEED
