what do i need?
David K
Your factory fuel pump is probably ok, but you will need some sort of return line, which would not be a bad idea anyway since it would circulate your fuel. You will need a pressure regulator to regulate the pump down to about 3.5 psi, so it might be a better idea to get a pump for carb engines.
You could go with a nice set of SU's, or 3 two barrels. I never was a fan of the four barrel setup or the downdrafts. If you are after more performance, the three two's are the way to go.
Why do you want to switch BTW? Might clarify the picture a little better.
