jzd14 Posted December 21, 2001 Share Posted December 21, 2001 the accelerator pedal on my 240z is extremely sensitive with only a little bit of pressure,the engine revs up really high making it hard to control the engine speed do u guys got any ideas on what to do so it's not so damn sensitive? Quote Link to comment Share on other sites More sharing options...
Guest RXO510 Posted December 21, 2001 Share Posted December 21, 2001 Have you tried putting a stronger return spring on? Maybe the one you had broke or came off somehow? I think a stronger return spring would make things alot easier for you. J Quote Link to comment Share on other sites More sharing options...
jzd14 Posted December 22, 2001 Author Share Posted December 22, 2001 i don't think there's anything wrong with the spring but would changing to a stiffer spring make it not so touchy if so, where could i get a stiffer spring? Quote Link to comment Share on other sites More sharing options...
Guest RXO510 Posted December 22, 2001 Share Posted December 22, 2001 Kind of sounds like the way your throttle reacts; you are missing the return spring or something. Try revving your engine manually from the carb and see how it reacts. Stiffer spring would make the pedal alittle harder to push, making it alittle bit easier to manage. I've seen spring kits at PepBoys, Kragen, Autozone. A package of 3 different tension springs for 3.99 or so. Does your engine idle high after you get on it? Or does it return to the normal rpm at idle? Just try another spring to see if it makes a difference for you. Goodluck! Quote Link to comment Share on other sites More sharing options...
jzd14 Posted December 22, 2001 Author Share Posted December 22, 2001 the engine idle returns to normal after u take your foot off the gas thx for the info...i think i'll try and swing by autozone today and pick up some springs Quote Link to comment Share on other sites More sharing options...
Guest RXO510 Posted December 22, 2001 Share Posted December 22, 2001 Sounds like you don't have much of a problem then. I kind of like the throttle to be on the responsive side. That's just me. Maybe you just need to get used to driving the Z that way. Easier to rip and burnout on other cars. Well I'm sure the stiffer return spring will help you out some. Keep me posted. J Quote Link to comment Share on other sites More sharing options...
