fl327 Posted November 18, 2001 Share Posted November 18, 2001 hey im having a weird issue with my 280. it will idle just fine, drive fine, but once i start winding down, slowing down and getting ready to stop and what not, the idle jumps up and sticks to like 1500-2000rpm, once i get back on it the idle drops back down and i am normal again. also, it will idle fine on start up, but once i hit the gas, it will stick at around 1200??? any clues anyone? Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted November 19, 2001 Share Posted November 19, 2001 I had a similar symptom on my Cutlass; turns out it was the Cruise Control Servo Linkage that was pinching the throttle linkage. It too would idle fine at an initial start up-but once you gave it some gas it would stick & you counldnt get the engine to kick down; it's idle was stuck at 1200rpm's. Check your throttle linkage or R&R the throttle linkage/make sure it isnt binding. A week throttle return spring could cause similar symptoms. Also had a 66 Cutlass once that had the exact opposite problem; initial idle was fine but once the engine warmed up it would die at idle. Turned out the carb.base plate gasket was defective & interferring w/incoming air. Once I put new plenum gasket on everything was fine. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
labrat Posted December 9, 2001 Share Posted December 9, 2001 Could also be the BCDD, i believe on that model it was used to decrease emissions during shifts, etc. I eventually just filled mine with body putty and drilled the correct diameter hole to get the correct adjustment with the idle screw. Mine leaked all the time, though. The BCDD is connected to the speedo, and any time your over 10 mph and let off the gas suddenly, it allows air to leak around the throttle blades to burn the fuel that is already in the system. worth checking out anyway... Bill Quote Link to comment Share on other sites More sharing options...
DavyZ Posted December 9, 2001 Share Posted December 9, 2001 Leonard, If your car idles too high, just take a big pair of wire cutters and go over to the harness, make a big snip and all of your idle problems will go away. Don't you wish it were that easy? Davy Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 9, 2001 Author Share Posted December 9, 2001 yeah that always works no what i did first was lube up the throttle cable, idle dropped considerably, then i change the timing to haynes specs, was previously advanced a little bit. idles cool. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 10, 2002 Share Posted January 10, 2002 ....your car HATES YOU!....have you done something to it that it didnt like?...did it want to go out on a date w/a mustang and you wouldnt let it go?.....just kidding....does your's have a "cold start" solenoid (valve or whatever)...? ..s Quote Link to comment Share on other sites More sharing options...
