Low fuel light doesn't come on
I tried feeding the bulb from a 6V NiCad I had and it glowed, so I think the bulb and the wire are ok. Then I checked for power at the dash with the test light, and it goes on with the key (way low on gas right now, don't know if it'll go OFF.)
So when it quits raining, I'll go put some more gas in there, and see if the light will go off. If it does, then the connector is faulty.
Is there some kind of conductive grease you can put on the pins in case the contacts are too loose?
Update:
I put the fuse in and the test light goes on showing the circuit is on. Then I filled the tank up to half and the light didn't go off!
How full do you have to fill the tank for the FUEL flight to go off?
Can you test the low level sender separately?
