Car Moans
About 2 days ago I had to stop real hard in traffic. Since then, the car has been "moaning" when I slow down (seems to do it most at real low rpm ~1000...) it also moans when I turn. When the car moans..there is a little bit of vibration in the steering wheel...
any ideas?
ps...not a z....94 bmw 325i
Try taking out the pads and roughing them up. I usually just rub the friction surface on the concrete driveway in a figure 8 motion. Maybe they got glazed? Also check the rotors for runout and make sure the calipers are sliding freely.
HTH.
Tim
so, you think its the brakes? that was my first thought...but it also seems to do it when I'm taking off from a stop....or if the car is in drive..and the brakes are all the way down and car is not moving any (so they cant be slipping)...and I turn the wheel..... that made me think not breaks..but you definately know more about cars than me....
okay...will check those..anyone else got anything? ..how bout some more info on that torque converter thingy...would it still happen if I turned off OD...(not sure if I can...its not my car..is my GF's...i dont plan on just not using OD..just as a means to test...)
doesnt feel like its trying to stall...sounds almost like something is rubbing against the wheel..or something like that...if ytou know what I mean..but I cant find anything that is....
I'll give it a try
Sounds to me like a caliper or two is sticking closed when you break. I have had a car and van and a truck where this happened. It had the same symptoms that you discribe. One time it was the master cylinder and the other two times it was the break line right before the caliper. Both were easy fixes.
