wiring "euro taillights" so they work right !
Guest LAYTON
Guest greimann
Check to see that the ground wires of the turn signal bulbs and stop lamp bulbs are correctly routed. It sounds like you have the ground wires of the stop lamps connected through the filament of the turn signal.
I have that problem with mine also - I haven't fixed it yet.
The problem is that it's not a direct bolt in. The wiring on the Euro cars with these lights is different. The Euro lights have separate brake ONLY bulbs, where the US lights have brake/turn bulbs. So you need a new wire to the rear of the car that is hot when the brakes are on. It's not easy to explain, but I'll be working on this and post some schematics, etc.
