riverz Posted December 19, 2002 Share Posted December 19, 2002 I need some help here its driving me crazy. It will not charge unless I rev it to 4500 or more then it will charge even at idle. For a while then it drops to 12 v and the red light comes on and a relay under the seat chatters then you have to keep it reved up and its barly charing. Heed help have to fix it tommrrow. please help. please. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 19, 2002 Share Posted December 19, 2002 since you didn't give us a model year... Kragen and Autozone will test the alternator/charging system for FREE. You might also need a voltage regulator if equiped. Quote Link to comment Share on other sites More sharing options...
riverz Posted December 19, 2002 Author Share Posted December 19, 2002 sorry its a 78 280z 2+2 I already took it to shucks and they said that it was good. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted December 19, 2002 Share Posted December 19, 2002 Check all your grounds. Sounds like something is loose. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 20, 2002 Share Posted December 20, 2002 a 78 280Z has a voltage regulator.it's most likely the source of your problem.it's located on the back of the black bracket on the passenger side next to the strut tower Quote Link to comment Share on other sites More sharing options...
riverz Posted December 21, 2002 Author Share Posted December 21, 2002 update I got it fixed. It was a bad voltage reg but it was in the alt. replaced it worked fine shows what you can find out at shucks. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted December 21, 2002 Share Posted December 21, 2002 i have a 77.for some reason nissan wired the red led in volt meter to a relay under the seat that hooks up to something else-i dont remember.i remeber ripping out extra stuff when installing 81zxt drivetrain/ecm.any way i converted to internal regulator 85 amp turbo alternator.you just have to extend 2 wires from regulator plug to the new alt.when i do this stuff i never document it-i should.1 wire runs the led in volt meter and 1 is a key + for field . Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted December 22, 2002 Share Posted December 22, 2002 yeah i ran into that same prob. an yr ago, just posted on previous topic about battery dying. Cool you found out quick. they told me everything was fine with my equipment and it was the wiring. they were wrong as usual. cool to see a quick resolution to your prob. Quote Link to comment Share on other sites More sharing options...
