If It Would Only Run
I just finished installing phatom autometer gages in my dash. They look great!! Only problem is I am going to have to enjoy them in my garage. I now only have spark from the coil when the ignition switch is in the on position. No spark when key is in start position. I can get started by bumping the starter and then quickly letting go of the key but it is difficult. The tach works but I must have left something not connected of connected it wrong. Any help, suggestions, comments, insults, or input would be appreciated. Thanks Mark
Yes that must be exactly it ! I did the same thing a million times , except I usally do it down at the starter, then realize what happened , a quick switch of the wires and off ya go! good luck, hope thats it . Tony
74 260, sbc 350, 700r4, and a few little HP Mods.just gettin started good. www.speedtechcoatings.com
I wish that were it. Car will run just VERY difficult to start. I'm about ready to rip all the wiring out and start over. This SUCKS!!! Well I feel better now, back to the Z. Thanks guys, Keep the suggestons coming. Mark
Mark,
I was getting migraines form my ignition switch.. It either wouldnt start or the key would jam up or fall out. so I put a switch on the dash for the fuel pump and the ignition and wired in a push button up under the dash to start the car. To hell with the key. If you dont kow where the button is..cant go anywhere. If you want more info on this type stuff let me know...
Vicki-aka The280Gal
Mark,
I have the same setup as Vickie, Except mine is mounted on the roll cage... Get one, and you will be much happier.
Mike
mjk
Hey Guys & gal altho I haven torn in to that part of my project yet, My car already has a push button mounted on the center console, was the keyswitch an inhearent problem on these cars, I am kinda worried that I am gonna be in trouble when I get to the wiring on this car... Tony
The tumblers in the switch just wear out and cause the switch to fail. Getting replacements can be costly, so I just went with the Moroso cage mount box to control all my particulars. I do allow the ignition switch to turn on the power to the accesories and the guages.
Mike
mjk
