utvolman99 Posted February 19, 2003 Share Posted February 19, 2003 First off I have a 73 240 and am wanting to go with aftermarket bushings. I would like to buy a kit. Here is the problem. I am installing a R200 rearend. Can I just buy a kit for a 280? What else would be different? Also, where can I find the best deal on the bushings? Thanks Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted February 19, 2003 Share Posted February 19, 2003 I think all the rear end/control arm bushings are the same for all Z's, cause my mustache bar bushings fit both the R180(factory with my 73 240z) and R200(pulled from 78 280z) bars with no problems. Victoria British list their kits for all 240z years seperate from the 260/280z kits, and the only difference I noticed in the kits is the rear sway bar bushings and the trans mount bushings included in the 260/280z kits. Hope this helps...... Chase Quote Link to comment Share on other sites More sharing options...
Guest KraZ4spd Posted February 21, 2003 Share Posted February 21, 2003 Call MSA.(Motorsport Auto). They can send you a kit for that. Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted February 21, 2003 Share Posted February 21, 2003 Got mine from Victoria British. It only took a couple of days to get to my front door. Quote Link to comment Share on other sites More sharing options...
ianz Posted February 21, 2003 Share Posted February 21, 2003 I'm all for supporting VB and Motorsport, but they jack you pretty hard on the bushing kit.... check this out...http://www.suspension.com/part_order.htm and save a few $$$$ cheers Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 22, 2003 Share Posted February 22, 2003 All of the bushings from the early kit will work with your new rear components. The rack bushing are different so order the kit for a 73. Quote Link to comment Share on other sites More sharing options...
