Canfield 195 or AFR 195 SBC heads?
Pete,
You guy's have me scared shitless, :shock: I got my canfield heads from Competition Products and now I read they are crap! :evil: I am going to call Competition products and Canfield first thing monday as Canfield reps told me to buy my heads complete from them as they offer the best price/bang for your buck.
I had mine cnc'd and upgraded to double roller springs good to .650 lift for my hydraulic roller cam: Comp cams 236/242-520/540 ls.110.
If they hesitate at all I will refuse delivery and charge back to Comp. products and demand Canfield make it right for the same price. If they refuse then I will go AFR and let everyone know what went down.
Crap I hope this is not the case..Fingers crossed.
Grumpy! Have you heard any of this around your neck of the woods?
Mike
This is one of those cases, we'll have to check out the Canfield heads when you get them, I have seen many Canfield heads, that were in excellent condition right out of the box, but I always buy dirrect from canfield,yet I have heard, of several incidences where they were not in top condition. Wait until you get them, inspect them carefully, and if they are not to the condition you think they should be sent them back. In general. Canfield heads and I have seen have been very good condition, you can easily have been checked, and any good head porting shop with a flow bench. I think you find any major problems are obvious just by looking. In general I do not think you will have to worry about those heads being bad shape.
just some EXTREMELY IMPORTANT INFO
http://purplesagetradingpost.com/sumner/techinfo/heads1.html
http://www.geocities.com/z28esser/headcomp.html
http://www.dw1977.cz28.com/photo2.html
http://www.canfieldheads.com/heads.html
http://www.kendrick-auto.com/head_flow_figures.htm
http://www.chevyhiperformance.com/techarticles/41598/
it's very hard for me to express strongly enough how important picking the correct cylinder heads and matching cam are to the results are likely to get from the engine, the best advice I can give you is to spend at least a third of your total budget on the cylinder heads and cam on any engine, a block and rotating assembly should also be approximately one third the cost of the total, the remaining third will be consumed in machine work costs, and parts like oil pans and intakes,etc.
it. If you are not spending approximately that ratio you're unlikely to get the most out of the engine.
Grumpy,
The Canfield heads are going on my sbc 350, 30 over with 10 to 1 compression, Comp cams Hydraulic roller 224/230-502/510 with 110 ls., 1.50 roller rockers, Weiand Stealth dual plain intake, Holley 750 DP with proform main body and 1 5/8" Hooker super comp long tube headers.
Heads are Canfield 195/200, 197cc, 65cc chambers, 1.60-2.55 valves, heads are intake cnc'd. Double springs 1.53 with 135 lb seat pressure and good to 630 lift.
Anyone have any idea's what this will give me on Desktop Dyno?
Mike
Those heads will soon to be put on a fresh 383 sbc this winter.
