Transmission model number. Where is it???
Z_Dust
:( ...you won't find a model # on the older transmissions. You have a couple of options to 'discover' what you have:
1. turn the input shaft in each gear and count the revs on the tailshaft and calculate the drive ratios, then compare to Datsuns published #'s
2. open the case and start recording bearing #'s, take them to your favorite bearing supplier to cross reference - or compare to Datsuns fiche for ID - hopefully the bearings are original.
The #'s you find on the xmsn case are useless - the has been no cross reference found (at least in this vast membership) that has proved meaningful.
Get youself a fiche on CD from Courtesy Nissan in Richardson TX for the model year you need here : http://www.courtesyparts.com/secondtier_s30.html
