Not sure where to post this. Latley when I hit about 70 MPH I hear a loud rattle develop just behine the drivers side in the quarter panel area. As I decelerate it get louder untill about 60 or so, then goes away. Some times it remines me of the sound a tire thats comming apart makes. Its getting worse, and now sometimes I hear it as slow as 30 MPH. Any ideas? :cry:
Just had the wheel rebalanced, not the problem. Can a wheel bearing make this kind of sound. I'll check that bracket right now. thanks guys. :oops:
Usually wheel bearing make a humming/droaning sound.
Have someone lay in the back of the car and see if they can pin it down?
Tim
Not the antenna bracket, it's already been removed. :roll: I replaced the shocks last weekend, but this rattle started a month ago. It's just getting worse and more frequent. Can the strut mount make this kind of rattle and still look good and fill solid when I had it out replacing the strut? :oops:
Guest Tim78zt
what did you use to tighten the gland nut to the shock tower? It may have worked itself loose (again!)?? Which bump stops did you use between the nut and the strut mount (bushing)? Urethane?
Tim78zt (still just guessing!!)
I agree with the comment about the ujoint in the half-shaft. If one (or more) of the bearing cups goes dry, it's usually a logorythmic degradation from there. The post(s) will get ground down, cause a little bit of vibration, that makes the wear even worse, etc. It'll cause noticeable noise/vibration at a certain speed. Then that speed range widens out (say, goes from 65-70 to 50-75, etc) until the unit completely fails.
Waaaaay long ago my passenger side shaft had a joint go gradually bad like that until it was just crazy bad. Had one post of the joint ground down to a little nub that rattled around inside a highly messed up bearing cup (with no bearings left of course). I switched to CV joints rather than mess with rebuilding those shafts.
While the rattle is happening, try holding the gas steady and feathering in the brakes. If the tune changes as you ease into the brakes, I'd look at the u-joints and the flange bolts(both ends) very carefully.
John
Guest Tim78zt
I'd say 325 ft/lb is a good way to check them already. Time to replace them with CVs if you're twisting them that hard!! I'm glad you found the answer!!
Tim78zt
