Guest 400 ci 280z Posted February 17, 2002 Share Posted February 17, 2002 i just got my engine from my uncle and i am a little worried about which one it is. does any one know how to identify a pontiac block out of a 76 or 77 trans am? the heads say 6x but i am not for sure if those could be on a olds too. i hope someone can help because i am about to go crazy and start pulling out my hair. Quote Link to comment Share on other sites More sharing options...
Mike C Posted February 17, 2002 Share Posted February 17, 2002 6x are definitely a Pontiac head. There are several different versions that all have different combustion chamber volumes. They were found on 400 and 455 inch Pontiacs. Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted February 17, 2002 Share Posted February 17, 2002 that makes me feel a lot better hearing that! thanks Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 17, 2002 Share Posted February 17, 2002 The year is stamped in Large Numbers beside the Distrib hole. Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted February 17, 2002 Share Posted February 17, 2002 on the drivers side it has F049 and on the passenger side it has DN with a 5 under it. the date tells me that it is a 69 block because it has 3 freeze plugs and 2 motor mount holes. thing is my uncle said it was a 76 or a 77 trans am he had. do it just is not making any sense to me. Quote Link to comment Share on other sites More sharing options...
Guest jens Posted February 17, 2002 Share Posted February 17, 2002 6x is a 77-78 trans am 400 head with 1.66" exhaust valves. I think it has a 96cc combustion chamber. With a 1.77" exhaust valve or a little exhaust porting it flows just as good as a 400 96, 7k3 or 455 64 head from 70-73. Many 455 owners use it to raise compression to 9.5:1. http://members.boardhost.com/boyleworks/?960122923 http://www.pontiacwarriors.com/ http://www.chiefmanyhorses.com/iacatalog/indian_adventures_catalog.htm Supercharged efi 455 http://www.osterlen.com/alf/ Quote Link to comment Share on other sites More sharing options...
Guest jens Posted February 17, 2002 Share Posted February 17, 2002 Here is a few combinations and a picture of a pontiac engine. 6x-4 heads is one of the best d port heads to modify because they have more meat around the 2 siamesed exhaust ports than other d ports have. http://www.boyleworks.com/ta400/psp/featuredcars.html Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted February 17, 2002 Share Posted February 17, 2002 thanks for the sites. also can anyone clear up the date issue? Quote Link to comment Share on other sites More sharing options...
Guest jens Posted February 21, 2002 Share Posted February 21, 2002 Here is a site with good information. http://www.pontiacs.org/ 6x is 76-79 400 heads. Quote Link to comment Share on other sites More sharing options...
Guest jens Posted February 21, 2002 Share Posted February 21, 2002 Here is detailed information as there is several versions of the 4x head http://members.tripod.com/futom/id59.htm engine block codes. http://members.tripod.com/futom/id113.htm Quote Link to comment Share on other sites More sharing options...
Guest jens Posted February 21, 2002 Share Posted February 21, 2002 Sorry meant 6x Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted February 22, 2002 Share Posted February 22, 2002 thanks for all the links jens. they gave me A LOT of info. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 10, 2002 Share Posted March 10, 2002 6X heads had 2 varieties: 6X-4 and 6X-8's. A pontiac block with two holes IS an early block. They can be used in later applications with modified or adapter mounts. Quote Link to comment Share on other sites More sharing options...
