Guest Anonymous Posted March 13, 2003 Share Posted March 13, 2003 OK, I've committed to doing the 240mm turbo flywheel upgrade in order to hold down more torque. Here is what I have now: 82 turbo flywheel (being resurfaced) SPEC stageII clutch kit (disk, pressure plate, TO bearing) What else do I need for the conversion? I currently am running a CenterForce DF clutch on a coupe flywheel using the 280Z TO collar. I've been through the archives on both here and Zcar.com and come up with conflicting information. Do I need a new: Clutch fork? TO Bearing Collar? Slave cylinder? Master cylinder? The clutch and flywheel are going behind a stock 82ZX 5-speed. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted March 13, 2003 Share Posted March 13, 2003 I'm in the process of converting to the 240mm flywheel. I changed everything you listed except the TO bearing collar. Does the 2+2 trannys and standard trannys use different collars? I thought they were the same because they use the same TO bearing but now I'm reading that they're different. Anyone know for sure? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 13, 2003 Share Posted March 13, 2003 I just picked up a new collar just in case. I went to Autozone and picked up a throwout bearing assembly. It comes with a new collar. I noticed that the P/N is different between the coupe and 2+2 with 240mm clutch. Total cost for the assembly was $24.00. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted March 13, 2003 Share Posted March 13, 2003 If I remember corectly, My SPEC clutch set came with the collar on the t/o bearing. I bought the 240mm carbon sprung hub set, and it holds it... Quote Link to comment Share on other sites More sharing options...
