me thinks me broke it !?
I have a 71 240z, it wouldn't start found no spark, then found no power to coil? so I hooked up a hot lead to the positive side of coil startd and ran fine, now nothing else works! no horn, lights, guages nothing, all fuses are good and have power something somewhere got blown or disconnected, anywhere I can look for online wiring diagrams ? anyone know what I blew and where ? I still have the old dasun ls so none of the wiring has been monkeyed other than the hot wire I ran to get it startd, any ideas ?
Fuseable link? Some of the "wires" are actually rated to open up with excessive current, just like a fuse, but they look like wires. You need to find and check those bad boys.
Also make sure your ground straps are connected.
If there is such a thing, you have one of the easier wiring problems to figure out. Using a wiring diagram and a test light, start at the battery and work your way down the wire until the light goes out.
