So far so good!
Guest BigWhyteDude
if you dont mind my asking how did you stop the leak?? Did you just put a bigol fat beed of sylicone there or something more professional? :?:
I changed from Permatex rvt to GM blk rvt. Also I used some very light sand paper on the block rails to make sure all oils and grit were removed.
Cleaned everything with carb cleaner. Also I ended up using the cork ends
on the back side of the block with a small 1/8" bead. The front I used pure RVT. So far so good!
