Tried to bleed clutch and Wilwood slave today-need help
Ferd/289
I tried to bleed the Tildon clutch master and slave today. Never got past the master as the plastic reservous had a leak due to a crack. I am using the mity vac.
I need to know the bleeding proceedure to do this job. I guess that you bleed the master first. Then, bleed the slave which is at a lower level. Then probably go back to bleed the master again to insure air is purged totally.
ALso, can I buy the pastic reserve part, or do I need to buy a new master. I so can you suggest a place to buy from?
