OK, are the "turbo" rocker arms actually differant
Guest JAMIE T
Guest JAMIE T
I want to put a cam in my L28ET. I was looking for rocker arms. Found some reman. rockers for maybe $5 each. Then, I'm looking in MSA and see the turbo rockers listed as differant than regular L6 rockers. The engine is an '81, so it doesn't have hydraulic lifters, so why would they be differant?
No difference that I am aware of. Have you tried Delta Cams resurfaced rockers? I ran a set in an NA head with a new cam and they were very queit with no unusual wear.
I am going to run another set on a cam for my turbo ZX to, just haven't gotten around to installing it yet. Want to see what the car runs like after my latest mod's before swapping the cam.
Guest JAMIE T
Lockjaw, I was thinking of using the Delta resurfaced rockers. That is why I was wondering if all the L6 rockers are the same. Thanks for the heads-up. Do you have any contact info for them?
