Mudge Posted March 26, 2003 Share Posted March 26, 2003 Quote Yeah but I don't know what Darius has programmed on this computer that I bought from him!? Since it was a blown car, I doubt the use of 7k RPM, why not look at what is in the PCM? That is the best way to find out. $69+$20+$65 My 94 has the connection to the coil module that you show, plus two more connectors that connect side by side at the top of the coil. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted March 27, 2003 Author Share Posted March 27, 2003 Here's what I "think" I have figured out... I have the early style coil set up on the engine. However my harness has the 96+ stlye connections. I dont hava anywires though that would plug into the top of the coil? What are those there for? I am going to an after market set up so maybe I dont need them? Darius was using and MSD set up. Does anybody know what those wires up on top are for? Oh yeah, Danno I go those pics! Thanks a lot. That really helped! Just a little update on my engine building. I got the whole bottom end assembled and Plastigauged this week. I put the Cloyes double roller timing chain on today also. I didnt advance the cam timing though. Then I put the heads on today and torque them down and then torqued to yeild them. After that I put all the push rods in and put the new 1.6 roller rockers in. I will be done next week!!! Oh baby! Hopefully in about 2 weeks I will get to hear it run!!!!!!!!!!!!!! Guy Quote Link to comment Share on other sites More sharing options...
80LS1T Posted March 27, 2003 Author Share Posted March 27, 2003 Now I am thinking about getting a Crane System!??? Only thing is I dont know if they make an adapter for my harness? Do they? I have the 96+ connections on my harness. JEGS----- Here is a part number for what I think I need... 270-6000-6708 GM HEI /Ext. Coil Adapter Harness This is the system... 270-6000-6466HI-6TRC CD Ignition w/Timing Retard, Allows 0-20° Driver Adjustable Timing Retard in Under Dash Mount Switch. I could really use some help here! Guy Quote Link to comment Share on other sites More sharing options...
Guest Your Car is Slow Posted March 27, 2003 Share Posted March 27, 2003 Ok..just went out and looked at my 93 LT1 engine. I have a single post connector at the top that goes to the opti. I have a rectangular connector about 2" down from the post at the top (sorry..harness is off the car..so I dunno where it goes). Then about 4" below that on the thin plastic shroud below the coil itself I believe is the ignition sending unit. It is that I believe the harness should splice into. God its been awahile since ive played with an LT1 (and never with a 93). anywhoo..if this sounded like what you have...then you have a 93 style Quote Link to comment Share on other sites More sharing options...
80LS1T Posted March 27, 2003 Author Share Posted March 27, 2003 Well I know what system I have on my harness now so thats all that matters I guess. However can someone help me with my Crane system questions? Thanks, Guy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 27, 2003 Share Posted March 27, 2003 Call or e-mail a crane tech support. They should be eager to help promote their product. Quote Link to comment Share on other sites More sharing options...
