No progress this weekend on turbo swap
While looking over the turbo engine found broken exhaust manifold stud at the rear of the eninge. Can't get a drill on it unless I pull the intake manifold or get some angle air drill(maybe). Then found that all three studs on the downpipe are broken off by whoever pulled the engine. So I start to remove the downpipe to work on this and break the EGR fitting because it is brittle. So I think EGR is history, I am just making a plate to block it off on the intake manifold. I had to remove the EGR valve to put penetrating oil on the fitting so I can remove it from the intake manifold, so I will just leave it off. So this weekend only lead to more work to get this swap completed, frustrating.
