Grumpyvette??
Okay, I am still having problems selecting a cam for my build up. I am choosing between a xe268 and xe274 for my street build up.
Vic JR intake
Iron Eagle 215, 2.05/1.60 small cc heads
700R4 W/stock converter
3.73 R200
650 Holley vac secondary
I have also contacted Dart for their suggestion on block hugger headers.
I would really like to go with stock flat top pistons. That would probably leave me with the xe274. Do you think I would have a detonation problem with this setup? What do you think the street performance difference would be between the xe274 with flat tops and the xe268 with a 12cc dish?
Also, when looking on darts home page they list my spring setup 1.437 as being for solid lifters? Does this matter. I was under the impression that they are just the higher lift springs. Do I have to switch gears and start looking for a solid lift cam?
Guest gbvol54
Vol Fan,
Sounds like spring training is going good. Hope that d-line firms up...
I'm sure The grumpmaster will respond shortly but from what I've read the Victor series is for high RPM hp while your cam selection may be a bit mild for that use. I'm considering those same cams with a set of Vortec heads with 10-1 static CR, but with a E-brock Performer RPM intake. With a Victor series you might want a bit more lift.
But what do I know. I thought the Vols would make the NCAA's easy....... Wait for Grumpy's input.
Well, if there is one thing you can count of Fulmer doing its shaping up the lines! I think they will be fine upfront! If you are interested in really great Tennessee information you need to try www.tennessee.rivals.com. Its really slow right now but next week things will be jumping again! 2thumbs.gif
As for the Victor Jr. grumpy had suggested using the Super Victor if it would fit and if not to go with the victor. I think the idea is that the car is so light you really dont need a dual plane intake! Also something you may be interested in I have a Hot Rod Magizine Nov 99 that outlines a build up with Vortec heads. They started with a junk yard 350 with a new timing chain oil pump, tune up and carb kit.
Stage one
90 350 TPI heads
Summit cam kit 214/224 dur 442/465 lift
Weiand dual plane intake
this produced
299 hp @ 5000 RPM and
368 lbft @ 3500 RPM
Stage two
Xetreme energy cam kit 224/230 dur 470/480 lift
319 hp @ 5300 RPM and
380 lbft @ 3900 RPM
Stage three
Vortec heads
Performer intake
375 hp @ 5700 RPM
395 lbft @ 4300 RPM
Stage four
Super Victor intake
Demon Carb
395 hp @ 5700 RPM
400 lbft @ 4800 RPM
The Super Victor had a really flat torque curve. It actually had more torque than the performer from 3600 RPM on up. I kown the Demon had a lot to do with it but I still dont think the tall single plane hurt it. With the bigger cams we are thinking of using I think it would sing!!
