Guest Anonymous Posted April 4, 2003 Share Posted April 4, 2003 if you have a cracked dash, would it be possible to sand out the peaks and fill the cracks with bondo? just wondering if anyone has done this. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted April 4, 2003 Share Posted April 4, 2003 Hrm, stock dash is foam right? Maybe try a SMALL amount of expanding insulating foam? Better yet a cap works and looks great Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 4, 2003 Share Posted April 4, 2003 Check your mail..... No mail address? Oh well, I'm not chancing showing any more businesses in here. I don't want no trouble! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 4, 2003 Share Posted April 4, 2003 SPIIRIT, hi i sent you a PM with my email address. i'm trying to do this with as little cost as possible. if i have to, i'll buy the dash cap. but right now, i need a new fuel pump, injectors, plugs, fuel lines, and hopefully a fuel cell so i'm a little broke thanks Quote Link to comment Share on other sites More sharing options...
love-my-V8-280Z Posted December 17, 2003 Share Posted December 17, 2003 Blackout did u try the bondo dash, I have been temped to thy it myself than re dye the dash and use a texure mat.... Terry Quote Link to comment Share on other sites More sharing options...
PETEW Posted December 17, 2003 Share Posted December 17, 2003 I think the makers of POR-15 make something that is to fill in dash cracks. I think it is an epoxy putty or something. I'm not sure but it might be something to look up. I know their paint works well. My entire underside is coated in the stuff. Quote Link to comment Share on other sites More sharing options...
akeizm Posted December 17, 2003 Share Posted December 17, 2003 I've done the that idea, instead of bondo I used some black glue. But I still had to paint over it to get it the same colour as the dash. It looks good compaired to the cracks, but a fully repaired dash is better. I'll get some shots of it, if I can get around to getting the camera from work. Quote Link to comment Share on other sites More sharing options...
spork Posted December 18, 2003 Share Posted December 18, 2003 Go to a decent bodyshop supply store and they'll have a filler designed to repair cracks in dashes. Simple as that. Quote Link to comment Share on other sites More sharing options...
monster626 Posted December 18, 2003 Share Posted December 18, 2003 i don't know if anyone else did this but i used fiberglass layed over the dash. 3 to 4 layers sanded and then bondod over to get it smooth. i then used rocker pannel spray to get the texture. after that i used primer and paint----so far it held up in texas heat. Installed 1 1/2 years ago. just thought i would through that in. Quote Link to comment Share on other sites More sharing options...
