Heavy Z Posted April 12, 2003 Share Posted April 12, 2003 Hello everyone, I've been tossing around the idea of swapping the 383 from my blazer with the 327 in my Z. I want to keep the tranny setup as-is, the Z has a T5 (I know a 383 will be pushing it, but it's been so good this far ) and the blazer has a turbo350 (good for the truck but not my Z) - please let me know if I can swap flywheels or if I need to buy others, and if so, where? Thanks for the help, Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted April 12, 2003 Share Posted April 12, 2003 An old article where Gale Banks put a 400 in a Firebird stated he had to clearance all the way around the bellhousing with a grinder to fit the larger flywheel. Also the only starter would be the 1996-2000 truck gear reduction one according to JTR. I'd say put a Hays 153 tooth in it. They drill out the balance. I tried a balance plate under a stock wheel when I went to a 400 but it would not let the starter disengage cleanly, so I bought a Hays I will put in one of these days. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted April 12, 2003 Share Posted April 12, 2003 Your flywheels should interchange just fine. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted April 13, 2003 Share Posted April 13, 2003 Your flywheels should interchange just fine. *Brain Fart* 383's are made with externally balanced 400 cranks. A neutral balance flywheel from a 327 won't work!. Look to what Mr. Phil1934 has to say above. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 13, 2003 Share Posted April 13, 2003 centerforce makes a flywheel for a extranlly balance 383 to a t5 you need to get ahold of centerfoce directly or a good tech at summit or jegs. Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted April 13, 2003 Share Posted April 13, 2003 Two other points. Although rare, make sure your block has the inline starter pattern for a small dia. flywheel starter as mine only had the staggered mount. And if you are running the stock harmonic dampener you will need a smaller one. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted April 13, 2003 Share Posted April 13, 2003 Centerforce has all their stuff online at: http://www.centerforce.com/pr03.htm Go to their flywheel section and get the part number you need, then call up your favorite supplier and get them to order that number for your combo. Mike Quote Link to comment Share on other sites More sharing options...
