zhins50 Posted April 20, 2003 Share Posted April 20, 2003 i am doin a turbo swap on my 240 and am currently using an 82 5 speed non turbo. i know that the turbo motors come with t5 trannies stock and was wonding if a t56 would bolt up to the l28turbo motor. i can deal with the tranny well that needs to be cut. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted April 20, 2003 Share Posted April 20, 2003 SSS510 mated one to the L6 for his 510. If you read enough posts, you'll find his info. Very fast 510 BTW. It can be done. Davy Quote Link to comment Share on other sites More sharing options...
brokebolt Posted April 24, 2003 Share Posted April 24, 2003 I e-mailed SSS510 a few times, he did mention cutting and trimming the tunnel, that made me think twice. The concept sounds dynomite though, if anyone does this conversion, it sure would be nice to get a detailed description for future project seekers. Does the T-56 mate up to the stock T-5 Nissan bell housing or would that need to be a custom job like Mr. SSS510's? Mike Quote Link to comment Share on other sites More sharing options...
Mike C Posted April 24, 2003 Share Posted April 24, 2003 Obviously it needs to be custom, or he would'nt have done it! Check out this website that Pete posted, they have tons of adapter bellhousings, and depending on the pattern on a Nissan S22 diesel, you might be able to use the Supra 6 speed: (Doesn't the Supra come with a 6 speed? The bellhousing says 5 speed.) http://www.rodshop.com.au/bellhousings.htm Quote Link to comment Share on other sites More sharing options...
Guest zline Posted May 13, 2003 Share Posted May 13, 2003 the nonturbo supras had 5 speeds. T56 on a L6 would be good only if you needed that extra overdrive gear, I'd rather have a close ratio rally geared early 5 speed, lot less trouble. Quote Link to comment Share on other sites More sharing options...
