D port heads and 2001 hooker headers
madmanadam
  • 3 weeks later...
  • 4 weeks later...
:oops:
copper RTV is great?
Adam
yes it is great in some uses, I find it too soft for exhaust sealing when you have a questionable surface (ie. you need the silicone to remain in place under some pressure). Between nice flat matched surfaces most all seem to work well.
I'd suggest building up the inside of your 2100's to match the D port better. Leave the header port slightly oversize but if you build it up and then file/machine flat you'll have a much improved sealing surface. I fought sealing issues for years on my setup and hope to now avoid it entirely. My father had his 2100's welded up internally to better match up to his Lt1 D port heads......otherwise they'd leak excessivly at that lacking mismatch on the bottom of the ports. HTH
