Magneto drive gear
Just got a steel drive gear for my Vertex. It only took a week from the local parts store. When I got it home, it turns out to be about .008 to large for the shaft on the magneto. I am at a total loss as to what to do. The guy at the parts store said that MSD, was a lot cheaper than Vertex (Which I had ordered) and that of course all the gears were the same. :( (I guess that i should have taken into account that he also9 said that Taylor doesn't sell Yellow wires) Can anyone tell me how long the bronze gear will run on a cast cam? Not that I'm upset, but if anyof you happen to have a few kilos of weapons grade Plutonium to spare....... :fmad:
All of MSD's distributors have a .500 shaft. The large cap HEI has a .500 shaft, the small cap HEI a .410 shaft, and the old points type has a .490 shaft. Sounds like the Vertex uses the same gear as a points distributor. That should make it easy enough to find.
