Cheap T88s?
Guest tt350
Guest tt350
Anyone know where to get a T88 that will be mounted to a LS1 or LT1 (still in the works). This is for a single setup.
For the double, whaddya guys think would be best for the GM?
The T88 is the greddy turbo right? I would bet you would have to get that from a Greddy dealer.
For a twin set-up, I would think something on the order of two 60-1's would be sweet, you would need to run a full T4 with a p trim turbine, and probably a good sized AR ratio on the housings, something in the .69 or larger range.
I would check with Innovative turbo, there is a mustang guy in Bham running one of their turbo's, and he is running low 7's in the 1/8th at 105mph or something insane like that. He likes their big single turbo, and says it spools pretty nice.
Good luck.
Mustang guy in Bham running one of their turbo's' date=' and he is running low 7's in the 1/8th at 105mph or something insane like that.
Good luck.[/quote']
No offense, but for a big single turbo on a mustang that does not seem that fast. I went 7.2@102.7mph in the 1/8th. I think the potential on a V8 should be much higher. I am not saying 105mph is bad or anything!
Guest JAMIE T
James is right. Thats only low 11's in the quarter. I guess thats kinda fast, but I had a Mustang that ran 10.90's with an S-trim Vortech, 14psi. Plus a built motor, but still fully drivable and had AC.
I am not offended, but I think he was on drag radials only, and the site is down or I would verify what he ran.
I also think that was on 93 octane.
James your car is fast no doubt about it, and I know you were on Nitto's, but you were also using NOS to get moving, so traction wasn't such an issue when I saw you run, traction for this guy is an issue.
There are faster ones, there is a guy that has a 9 second one, but I haven't seen it yet.
Guest Zcarsmakemyheadhurt
I just sold two T-88H's to a dude that is going to put them on a pair of supras. The T-88's from Greddy are Mitsubishi turbos and they are bulitproof and make lots of power. I like them, but they are expensive and take time to get. I can order you one if you would like that for your SBC, or I can size you a Garrett unit that will rock.
