R230
Guest 3154tm
zxgts-4,
Don't know if all the models did, but I've heard that the R230s in those models were
like 4.11 ratio?
"Phantom Grip, Nismo, Cusco, and Quaife all offer aftermarket limited slip differentials for the 1989-1998 240sx's for a few hundred dollars. Your other option is to replace your differential with a LSD model from another Nissan, about $300 at a junkyard. These are your easiest choices for a swap: all Canadian 240sx's and the 240sx's with Super Hicas had VLSD. You can also use the differential from a non-aspirated 1990+ 300zx- not the twin turbo version! The NA one has the same gear ratio (4.083:1) while the twin turbo one has a 3.61:1 gear ratio."
http://www.nissanperformancemag.com/index.php
Owen
