DAW Posted May 21, 2003 Share Posted May 21, 2003 Does anyone know the pin diameter and compression ht (pin ht.) for these pistons? Thanks in advance. DAW Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted July 1, 2003 Share Posted July 1, 2003 I've not come across any data on the VG30DE, but I've read and written down the Piston Comp.Height for the VG30E...which was 31.75mm or 1.25" As for the pin diam; who knows. This is the part that I hate about technical write ups on any engine; very rarely will the author give the Piston Comp.Ht nor the Block Deck Heights: and often times they wont even give the Con.Rod lengths Here is a simple request from me-going out to anyone who creates their own website representing their engine/car build....Please include the Piston Comp.Height & Block Deck Height on your engines! Thanks in advance 8) Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted July 7, 2003 Share Posted July 7, 2003 FWIW, WISECO Pistons lists their aftermarket Piston Comp.Height for a VG30DETT to be 1.260" with a Pin Diameter of .866" or 22mm. KB Piston's list their Piston Comp.Ht. for their VG30E as 1.25" also and its Pin Diameter of .8259" Offset. Doesnt appear that anyone actually lists the VG30D, as in listing the VG30 w/a "D": yet, they list the VG30 in other ways. If you are working calculations for this engine it appears you could probably assume a Piston Comp.Ht of 1.250 to 1.260" and you should be safe. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
David K Posted July 7, 2003 Share Posted July 7, 2003 I found this site a long time ago while searching for piston specs on an sr20. They only list VG30, maybe this might help a little. http://www.tomei-p.co.jp/_2003web-catalogue/e058_pston-specs.html Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted July 26, 2003 Share Posted July 26, 2003 Ok, mystery solved: yippie-yahoo. I found the VG30DE piston on the Arias Pistons site. It indicates a: 1.255" Piston Compression Height 10.6 Compression Ratio when using 49.5cc Cyl.Head Combustion Chambers FWIW: the rod length was 6.071 This listing was good for Nissan 3.0 L VG30DE DOHC 24v, 90-96 300ZX Non Turbo. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
