TPS Question for SDS and 240SX Throttle Body
Sean 83ZXT
I'm using a 240sx TB and TPS sensor. The 240sx sensor is both swith and potientiometer(sp?). For the sds you use the 3 wires coming from the bottom of the sensor, which is for the potientiometer part. Hope this helps.
-Austin
Oh btw no Z TPS sensors will work with sds because they are all switch type, but i figure you know that already.
I used a 240sx TB and TPS for my megasquirt.
It would only read from 3.5V to 5V. If you loosen the two screws that hold it on the TB, you can adjust it a few degress (that translates into volts to your SDS) either way. I found that I could not get the dynamic range close enough to 0-5V.
What I did was take the two screws out and rotate it a few degrees more than the slots in the TPS would normall allow. By rotating it about another 45 degrees clockwise, you will see that you can then put the screws back in and they will wedge the TPS in place. (You will know what I mean when you see it.) My TPS now reads from about 0.5V at idle to 5V at full throttle -- good enough for megasquirt and probably good enough for SDS too.
-Sims
Guest Zcarsmakemyheadhurt
I use a TPS from a new Nissian, mine has a standard type plug then a seperate lead with a connector on it, from a Maxima.
