Feeler, Custom intakes
I will be making custom intake manifolds for the L28 for you turbo guys. I will take the stock manifold and chop it 1.5" off the flange to retain the injector mounts. I will deck it in the mill and bore the ports to match the gasket. I can also leave it stock if needbe. I will then weld 1.375" ID(16G) tubing to the flange and on the other end a custom plenum. I will also port the inside of the runners for a smooth transition. The TB will be for a stock unit. However, you can send me your TB if other than Nissan and I will make the plate to fit your TB. It will have 1x 1/4 NPT hole for the brake booster and 5x 1/8 NPT holes for misc. vacuum lines. This will be on the back of the plenum. I should have the 1st 4 done by next week and will post pics. They will sell for $600. Please give me some feedback if you are interested.
