Guest Anonymous Posted June 17, 2003 Share Posted June 17, 2003 I have a 72 240z with a moderatly modified 355sbc, jtl conversion, attached to a TPI 700-r4. I have the git, 13.96 102.22 @5k altitude, but not the stick. I am running 235/60r14 tires, 3.36 gears and the tires just won't bite. My 60' times are in the 2.4 range. I would like to change the rear to a lsd of 3.7 ratio but I have no knowledge of what it requires, what will fit and what won't. Any help would be sincrely apreciated. It is a real grin to see the reaction of vettes, 5.0s and hot rods after we run. I am sure a little traction will help considerably. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 19, 2003 Share Posted June 19, 2003 Try this.... its right here on this page at top "Search" http://www.hybridz.org/phpBB2/search.php?mode=results Quote Link to comment Share on other sites More sharing options...
Drax240z Posted June 19, 2003 Share Posted June 19, 2003 Personally I would scrutinize your choice of tires before looking to change to a different diff! What brand of tires are you running? The grip that you are going to get out of your tires in a straight line is surprisingly unrelated to the tire width. (well, not unrelated, but compound matters very much more) Also, are you able to cope with the additional RPM's it will take to go the same speed with a 3.7:1 ratio over a 3.36:1 ratio? I'd spend the money and time on trying out some new drag radials first. Just my 2 cents. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 20, 2003 Share Posted June 20, 2003 I appreciate the input. My biggest fear is using a tire that has a solid bite and scrambling the rear end. From what I have read, the r180 is not stout enough for a stickey tire, so I figured on upgrading to a r200 and sticky tires. The engine has run 6800 so I'm confident of that. Found a great site, recommended in a much earlier, that shows rpm and speed @ 1/4, works out to right at 6k. thanks for your ideas, everything helps. Quote Link to comment Share on other sites More sharing options...
Guest thepenguin99 Posted June 20, 2003 Share Posted June 20, 2003 the r180 is a fairly stout rear although not as stout as r200/r230 rears I would probably run the 180 till it died...they are damn near impossable to sell anyway Quote Link to comment Share on other sites More sharing options...
80LS1T Posted June 20, 2003 Share Posted June 20, 2003 I think you should also look into some good drag radials. Get some BFG Drag radials and see what happens to your 60'. I think you will like what you see. Besides changing tires is way less complicated than changing differentals and putting in an LSD! Guy Quote Link to comment Share on other sites More sharing options...
